My camaro was running and out of nowhere it shut off, I replaced the fuel pump and my fuse is good and im not getting any power to the fuel pump or relay. I put starting fluid in the carburator and it wanted to start. I can hardwire my fuelpump and it does turn on, but still no power to the relay. I did change the relay and it is new. Theres has to be a problem in my ignition, any suggestoins? Thank you jeff
SPONSORED LINKS
Friday, November 21st, 2008 AT 7:33 PM
