1992 Chevy Camaro No Idle
140,000 MILES • V8 • 2WD • AUTOMATIC
86CADDI
My camaro RS was running and driving just fine a few days ago. I parked it in a parking lot for about a half an hour then it won't start. Now after towing it home it will start if I prime the TBI carb but when I let off the gas it dies. If I hold the gas it dies. I have to feather the pedal or it dies .I bleed the air from the fuel line and replaced the fuel filter and still no luck. I even siphened the fuel completly out and replaced it with new and still it won't hold an idle. I'm open to any idea's anyone has cuz I about out of them.
Sep 26, 2008 at 4:11 PM
  • 75,988 POSTS
Check the fuel pressure and comeback with the readings in order to continue-I need this to take out the fuel system
Sep 26, 2008 at 9:53 PM
86CADDI
I checked the fuel pressure it reads about 10psi.Could there still be air in the line?
Sep 27, 2008 at 6:19 AM
  • 75,988 POSTS
Below is the fuel pressure for V8 engine
https://images.2carpros.com/forum/automotive_pictures/12900_fuel_pump_v8_1.jpg
Sep 27, 2008 at 8:05 AM
