1992 Chevy Camaro Ignition timing
COBRA139
Engine problem
1992 Chevy Camaro V8 Two Wheel Drive Manual 121k miles
Hi, my son and I are working on his 92 camaro rs and want to make sure the timing is correct. There is no emisions sticker under the hood. It,s a 305tbi, 5speed manual tranny. Any help you can give us would be extreamly helpful.
Thanks,
Karl
Feb 18, 2008 at 7:30 AM
BLACKOP555
  • 10,386 POSTS
it should be firing 10degrees BTDC, gives enough time for the spark to go off right as the piston is getting up there.
Feb 18, 2008 at 10:17 AM
