1992 Chevy Camaro idle miss when warm
36,780 MILES • V8 • 2WD • AUTOMATIC
INDY59
I have tuned port injection 305 cid that runs & idles fine when it is cold. After the engine gets to operating temp it misses at idle only. I have put a new cap, rotor, plugs, & wires on it. I have replaced the fuel filter, & run injector cleaner thru it. Still no better. Any ideas on where to go next? I was told to check the injectors for a clicking noise when it is runing to see if they are working. They are all clicking. I am using autolight spark plugs gapped at .035. I was told that GM only likes AC plugs. I need help please! Any info would be helpfull.
Sep 12, 2010 at 2:27 PM
  • 75,988 POSTS
Try cleaning out the idle air control valve, EGR and PCV valves and test the throttle position and manifold absolute pressure sensor-Wrong type of plug will cause the engine to misfire
Sep 12, 2010 at 6:05 PM
