1992 Chevy Camaro gear cable selector
1992 CHEVROLET CAMARO
230,071 MILES • V8 • 2WD • AUTOMATIC
MELEEDUDE_1234
ok....I'm having a problem. I shift out park into drive it goes into drive, but when I shift it back it stays in drive. The gear selector cable has to be pushed back into park under the car. The stupid cable will not let me put my car back into any other gear. How can I fix this?
Feb 1, 2008 at 11:24 AM
MASTERTECHTIM
  • 4,750 POSTS
you wil have to replace the cable, unless the linkage holding cable to shifter came off, remove the cover over the shifter and look inside, tell us what you see.
Feb 1, 2008 at 11:26 AM
MELEEDUDE_1234
I can see whenever I shift it to another gear that its still connected. Next to the spring there is a black plastic cylinder that is in a metal plate, but when I try to shift it back it comes out of the plate and the cable sticks.
Feb 1, 2008 at 12:07 PM
MASTERTECHTIM
  • 4,750 POSTS
your going to have to replace the cable
Feb 2, 2008 at 1:58 AM
