1992 Chevy Camaro fan
195,000 MILES • V8 • 2WD • AUTOMATIC
JOET01
changed radiator fan stopped working, checked fuses and there all good. still over heating but fan will not turn on. what could the problem be the fan was working before i changed the radiator.
Jun 14, 2009 at 6:59 AM
JDL
  • 16,098 POSTS
Hello, any codes? Not only check the fuses, the fuse circuit has to be hot. Did you do any testing at the fan relay? On some systems if you unplug the cts, then start the engine, the fan will run. If you turn on the ac, the fan may run.
Jun 14, 2009 at 8:44 AM
