1992 Chevy Camaro exhaust manifld
BRUER
Engine Performance problem
1992 Chevy Camaro V8 Two Wheel Drive Automatic
i recently put a 350 ut of a 1970 caprice in a 1992 camero and i need to know what exhaust manifold i need to fit on the passenger side.
Sep 4, 2009 at 10:21 AM
HMAC300
  • 48,601 POSTS
I am taking it that this was not the original engine in the camaro. You could try the 1970 manifold as it may be similar to the newer one. Otherwise you would just need to get a manifold off another 1992 with a 350 in it as well. the bolt pattern has never changed on these engines even with the newer hir rail heads.
Sep 8, 2009 at 11:10 AM
CON_FUSE9
  • 8 POSTS
The 350 shared exhaust bolt patterns back at least till 1970. I would recommend you simply find a 305 or 350 exhaust manifold or buy an aftermarket shorty exhaust header.
Even the LT1s had the same port shape. (at least the same exhaust gasket).
Sep 11, 2009 at 9:09 AM
HMAC300
  • 48,601 POSTS
let me clarify something about these manifolds. On all small blocks the exaust pattern is the same. the difference on manifolds is size, where they exitmeaning they could be shaped different and whether or not they have mounting holes on them for various dress items. But when you put a 1970 engine in a 1992 car you run into the problem of if the exaust is going to go out the right place and whether it will hit the steering column shaft or something else. But in this case a manifold or a header for a 1992 camaro would work fine.
Sep 11, 2009 at 2:13 PM
