engine will start then stall after it warms up
1992 CHEVROLET CAMARO
ERNGRIFF123@GMAIL.COM
Brakes problem
1992 Chevy Camaro V8 Wheel Drive Type unknown Automatic 143000 miles
my car keeps dying when ever is been run for like an hour and then a day later it will start again?
Jan 28, 2008 at 10:33 PM
  • CERTIFIED EXPERT
Could be a fuel pump problem or the igntion coil-I'll 1st check the fuel pressure if its under specifications.
Try this if it refuses to start spray starting fluid in the throttle body-did it start up and die ? Does it continue to run while feeding t? We stop here till you comeback
Jan 28, 2008 at 11:43 PM
