engine will start then stall after it warms up
ERNGRIFF123
Brakes problem
1992 Chevy Camaro V8 Wheel Drive Type unknown Automatic 143000 miles
my car keeps dying when ever is been run for like an hour and then a day later it will start again?
Jan 28, 2008 at 2:33 PM
  • 75,988 POSTS
Could be a fuel pump problem or the igntion coil-I'll 1st check the fuel pressure if its under specifications.
Try this if it refuses to start spray starting fluid in the throttle body-did it start up and die ? Does it continue to run while feeding t? We stop here till you comeback
Jan 28, 2008 at 3:43 PM
