1991 Chevy Camaro timing belt
DETROITGREEKANGEL
Transmission problem
1991 Chevy Camaro 6 cyl Two Wheel Drive Automatic
my camaro was running rough the rpms red lining all the time the it just stopped in the middle of the road and wont start i think its the timing belt how do i fi it?
Jul 7, 2008 at 11:55 AM
MASTERTECHTIM
  • 4,750 POSTS
they dont have a timing belt.
Jul 7, 2008 at 11:57 AM
  • 75,988 POSTS
What you need to do- is do below and comeback and tell us what's missing fuel or spark this is where we start
Do you have a check engine light On or flashing prior to this problem?
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Jul 7, 2008 at 12:10 PM
