1991 Chevy Camaro Starting
1991 CHEVROLET CAMARO
38,000 MILES • V8 • 2WD • AUTOMATIC
MORRIS95632
Can only start car using starter fluid. After its started it runs pretty good. Checked fuel pressure, replaced distributer, coil, wires, etc. Replaced oil pressure sensor. It is the 5.7L TPI.
May 20, 2008 at 9:08 PM
After its started it runs pretty good. Checked fuel pressure, What was the fuel pressure? Do you hear the fuel pump for 2 secs when key at run position? Check the fuel pump relay-could also be the computer relay drive see below
https://images.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_51.gif
May 20, 2008 at 9:18 PM
MORRIS95632
Pump runs when ignition is on for 2 sec.
Pressure is 46-48 lbs. I have replaced the
oil pressure sensor. If there is a oil pressure sending
unit I can't find it.
May 21, 2008 at 8:07 PM
Try this locate the injectors and crank engine over and listening whether the injectors are clicking. If so test the oil pressure sending unit.
May 21, 2008 at 8:42 PM
