1991 Chevy Camaro stalling
CAMARO_711
  • 1991 CHEVROLET CAMARO
Engine Mechanical problem
1991 Chevy Camaro 6 cyl Two Wheel Drive 180xxx miles
i replaced the fuel pump, car runs fine for about 10 minutes then just shuts off. And wont restart
Friday, November 13th, 2009 AT 1:58 PM
ERNEST CLARK
  • 1,730 POSTS
Is your check engine light illuminated? If your car is shutting off, then the light should come on.
If it is, then that's the first place to start. Have it scanned for codes. That'll give you a good direction.
If no light is coming on, then it's a process of elimination.
Begin with your ignition system. Then the fuel. Then the sensors and finally the computer itself.
Friday, January 8th, 2010 AT 9:37 PM
