1991 Chevy Camaro serpinetine belt
RED_WING45
  • 33 POSTS
Engine Mechanical problem
1991 Chevy Camaro 6 cyl Two Wheel Drive Automatic
how do you replace a serpintine belt on a 91 camaro 3.1
Sep 16, 2009 at 3:44 AM
PEAR69
  • 1,482 POSTS
Find the belt tensioner pulley. There is a square hole that a 3/8 ratchet fits into. Stick the ratchet or a ratchet with an entention in the square hole, and loosen to release tension on the belt..Remove the belt and install the new one....It is pretty easy to do.
Sep 16, 2009 at 3:51 AM
