1991 Chevy Camaro ruff shift
172,000 MILES • 6 CYL • 2WD • MANUAL
GRNCAMARORS91
my 91 camaro rs is sometimes hard to shift it grindes when it goes in to reverse, also 1st gear is the hardest to shift into. why is it hard to shift.
Oct 17, 2008 at 9:16 AM
TEAG
  • 158 POSTS
It sounds as if your clutch is going out. That and/or your shift linkage is loose, damaged or needs adjusted. You also might want to check the fluid level.
Oct 20, 2008 at 9:09 PM
