1991 Chevy Camaro Replacing the engine
160,000 MILES • V8 • 2WD • MANUAL
THESHERM22
I just bought a 1991 camaro rs with a 305 tbi motor in it. However i am looking to put a Chevy 350 engine in it and i am wondering what i need to know in order to do it cleanly
Dec 15, 2009 at 4:04 PM
ERNEST CLARK
  • 1,730 POSTS
You didn't say what year motor you have. (L-98, LT-1, etc.) But it will bolt in with no problems.
However, the tbi will have to be reprogrammed for sure.
If it's a LT-1 motor, then you'll need an all new computer, fuel injection, ignition control, etc.
If it's an L-98 motor, then all you'll need to do is reprogram the computer to compensate for the extra cubic inches.
Jan 3, 2010 at 1:08 PM
THESHERM22
The 305 i have is stock in the 1991rs however i dont know what year the engine that comes with is and i have yet to buy a 350 i was just wondering what i would need to do it.
If i buy an lt1 i will have to basically reprogram everything to fit that type of engine but if i buy an l98 then i only have to reprogram the computer to fit the larger engine?
Jan 5, 2010 at 4:19 PM
ERNEST CLARK
  • 1,730 POSTS
If you were to by a 1991 L-98 350-cubic inch engine, then you could basically keep everything you have, but the computer would definitely have to be reprogramed.
It won't be able to compensate for the larger air/fuel demands of that motor.
Also, you may have to use larger injectors (Higher flowing) Other than that, small block motors of that era have completely interchangeable parts (External)
Now, it you buy an LT-1, you'll have to changed everything. You'll need to buy the computer, wiring harness, fuel and ignition system to go along with the motor.
Unless you are already familiar with that engine swap combo, I'd suggest you have a shop do an LT-1 swap.
Jan 5, 2010 at 11:16 PM
THESHERM22
Ok thank you very much i appreciate the help.
Jan 6, 2010 at 7:49 PM
