1991 Chevy Camaro no response from ignition
132,000 MILES • V8 • 2WD • AUTOMATIC
SASSIN01
The problem is; sometimes it cranks, sometime not. It doesn't seem to matter if the the engine is hot or cold. I have put less than 2000mil on it since a total tune up.
When this problem begin, my mechanic replaced the battery cable ends then the battery followed by the starter. Still it does the same thing. When you turn on the ignition the guages and interior light stays on but it won't even click. its like the ignition is connected to nothing. I am a single woman and though I trust my mechanic..........
Jan 14, 2008 at 12:52 AM
DWTOOT
CHECK TO SEE IF THE IGN KEY DIODE IS FUNCTIONING PROPERLY...THE CAR WON'T START IF IGN DOESN'T PICK UP THE KEY REGISTER...
Jan 28, 2008 at 9:07 PM
