1991 Chevy Camaro no fire
JIM HARRIS B
Electrical problem
1991 Chevy Camaro 6 cyl Two Wheel Drive Manual rs miles
starts sometimes now theirs no votage toclutch saety switch
Jan 14, 2010 at 6:02 AM
JDL
  • 16,098 POSTS
Welcome to the forum. Make sure the battery has a full charge and the connections are good. My info shows a theft/security system, if that is the problem, I won't help you bypass it. If you have the pellet in the key, wipe off the pellet with a clean rag, try a different key. Next, I'd check feed to and from the ignition switch.
Jan 14, 2010 at 7:25 AM
