If it inly comes on for a sec and then goes out the it probly doesnt hve codes listed but if you jummper terminals A and B the two upper rith most pins it will set the car into diag mode and flash the mil light if there is a code the it will show the first will be code 12 thats one flash, pause then two flashes, this will repeat three times the if there is a code set it will flash three times and so on for every code there after for example 5 flashes pause and then threee flashes is code 53. After you do this you can come back here and look up the codes it gives you in the code definations section.
It sounds like you might have a bad controle mod or pickup coil you can test these.
SPONSORED LINKS
Wednesday, June 2nd, 2010 AT 10:05 AM
