1991 Chevy Camaro horn relay
1991 CHEVROLET CAMARO
SKIPFEEDG
Electrical problem
1991 Chevy Camaro V8 Two Wheel Drive Automatic
where is the horn relay located on my camaro
Oct 7, 2009 at 12:54 PM
LOUT5369
  • 217 POSTS
It should be under the Left side of dash near the fuse panel,it'll be white with 3 wires going to it.If you hit the horn pad you should be able to follow the noise of the relay,if there are other things not working,I would check fuses first.
Oct 8, 2009 at 6:43 AM
SKIPFEEDG
Thank you
Oct 8, 2009 at 9:34 AM
