1991 Chevy Camaro hi
1991 CHEVROLET CAMARO
81,000 MILES • V8 • 2WD • AUTOMATIC
LEWIS198324
I Have a 1991 chevy camaro rs I just replace the spark plugs and gas filter and air filter and the pvc valve I also clean the iac senor i also check the plugs wires there where good . MY Question is that My car would pop though the intake and it would sputter. but it only does it once inwhile when you floor it it will clear out couild it be the fule injector sticking or the filter on the bottom of the injector. when you let sit for 1 hour it would run great.
Oct 8, 2010 at 2:16 PM
BILLYMAC
  • 2,204 POSTS
Hi this could be a blown intake gasket or a weak valve spring.check the vacum system really well especially all hoses and gaskets.
the eng needs air and fuel to run right when it backfires it is not getting one of those two key components
Oct 8, 2010 at 2:48 PM
