1991 Chevy Camaro Fuel Pump problem
306,000 MILES • 6 CYL • 2WD • AUTOMATIC
STAREGUY2006
My camaro's fuel pump will not turn off anymore. The only way to stop it from running is to disconnect the battery. I can hear air leaking from an area underneath the fuel injection and above the gas tank. Tried disconnecting the relays and it kept going. Attempted everything to disconnect the power to just the fuel pump but the only way to keep it from draining the battery is to disconnect it everytime I cut the engine off. Thanks
Sep 22, 2009 at 2:51 PM
  • 75,988 POSTS
Find the fuel pump relay and swap it with a like one and see what happens
Sep 22, 2009 at 3:53 PM
