My camaro's fuel pump will not turn off anymore. The only way to stop it from running is to disconnect the battery. I can hear air leaking from an area underneath the fuel injection and above the gas tank. Tried disconnecting the relays and it kept going. Attempted everything to disconnect the power to just the fuel pump but the only way to keep it from draining the battery is to disconnect it everytime I cut the engine off. Thanks
Sep 22, 2009 at 2:51 PM
