1991 Chevy Camaro Fuel Pump
MERK10
Engine Performance problem
1991 Chevy Camaro Automatic
i have a bad fuel pump i believe. i read online that my car shuts off while driving do to a fuel problem... i have changed my fuel filter and it helped alot but it still shutoff off on me. i do kno the the carburator was clogged and i used fuel injector cleaner to clean it out. It worked some but i think it still my be clogged. my main question is can a fuel pump on my 91 camaro rs be replaced with another model car or jus camaros?
May 12, 2010 at 7:32 AM
LEOMNR2008
  • 22 POSTS
it is best to replace the fuel pump with a new one but if you are going to go used it needs to be one from a camaro or similar car or truck with the same engine setup as you have.
also if the carb was cloged up you may need to pull it off and do a through cleaning.
May 12, 2010 at 4:05 PM
