1991 Chevy Camaro engine running hot
133,000 MILES • V8 • 2WD • AUTOMATIC
MYCAMARO
Need help controlling the temperature on a 305 engine on a 1991 Camaro RS. Changed the thermostat, flushed the radiator, hoses seem to be fine and just replaced the fan motor. Only thing that I can think of is that the fan is hooked up to a switch and does not seem to run any faster when it warms up than it is at when just turned on, could this be the problem?
Jul 15, 2010 at 1:39 PM
  • 75,988 POSTS
Could be a defective new thermostat, water pump not doing its job and airlock that's needs bleeding if all okay and continue to run hot -get it block and pressure tested.
Jul 15, 2010 at 11:29 PM
MYCAMARO
how would I bleed the airlock? I have never heard of that.
Jul 17, 2010 at 10:34 AM
  • 75,988 POSTS
Go here: http://www.youtube.com/watch?v=zUpXgAJ1gjU
Jul 17, 2010 at 11:02 AM
