1991 Chevy Camaro engine help
CAMAROCRAZY
  • 1991 CHEVROLET CAMARO
  • V8
  • MANUAL
  • 192,068 MILES
Hi this is eric and I am about to kill my camaro. Lately I have been getting obscene amounts of white smoke coming out of my pipes and the new thermostat its going nuts, jumping in temp as soon as the car warms up. Also the ol pressure is jumping around I have a new gauge and it says it runs from 40 psi to 80psi but sits mostly at 60psi. It is a chevy 350 v-8 out of a silverado and has numerous upgrades including a comp cam kit, keith black forged aluminum pistons, msd ignition, accel distributor, aluminum heads, edlebrock 600cfm four-barrel, and steel crank. Also power sterring is out and am wondering if this is a cracked head gasket or worse one of my aluminum heads is cracked. By the way this is a throttle body. Thanks a lot you might just save my camaros life
Saturday, February 9th, 2008 AT 8:52 PM
99NEON
Sounds like the symptoms of a leaking head gasket. It appers the white smoke is steam from burning coolant seeping in the cylinder at some point. Suspect a faulty head gasket. Prehaps over torqued a bit and with heat and contraction you may have a crack.
Wayne
Saturday, February 23rd, 2008 AT 3:53 PM
MASTERTECHTIM
  • 4,750 POSTS
Could also be a leaking intake manifold gasket
Saturday, February 23rd, 2008 AT 4:14 PM
