1991 Chevy Camaro ecm
GENEMUSHRUSH
Engine Mechanical problem
1991 Chevy Camaro V8 Two Wheel Drive Automatic
where is the ecm and prom located on 91 camaro.
and how do i know if ecm may be bad. i was wondering becuase i could crank the car up and unplug the map sensor, the mass air flow sensor and idle air control sensor and i heard no changes in the engine. Before if i did this the engine would shut off immediatley. the engine runs bad anyway and i cant figure it out it idles very roughly. but will take the throttle and sound fine when i put my foot on the accelorator.
Oct 27, 2009 at 8:29 AM
DOCFIXIT
  • 18,828 POSTS
ECM behind right side dash prom inside small flap.
Have you checked for codes?
Oct 27, 2009 at 8:35 AM
