1991 Chevy Camaro Car overheating
154,000 MILES • V8 • 2WD • AUTOMATIC
AKREIDL2009
I have a 91 camaro rs v8 5.0L, recently started to overheat and emitts white steam from the water pump, replaced water pump and thermostat, checked top and bottom hoses, checked radiator for buildup but nothing, still overheats. Also even while the steam is coming out the radiator is completely cool, the cap is good not loose or anything and apart from a few drops of coolent no major leaks. Is it mabey the radiator fan? Or something internal? Overheats slowly while in park or neuteral, overheats faster in drive. Runs good theres no engine knocking or anything when its idleing or when im reving it. Any help would be appreciated alot.
Nov 28, 2009 at 12:45 PM
GOTAY5
check the relay on driver side top of the booster, brake. One is for the AC the other relay is For The ENGINE cooling fan
Nov 30, 2009 at 3:58 PM
