1991 Chevy Camaro Burning rich,missing
93,000 MILES • V8 • 2WD • AUTOMATIC
MIKERP
350 eng TPI.The car sits a lot.Started this last time,battery dead,wouldnt charge,replaced battery.It misses really bad after warm up.Smells bad.done complete tune up.Replaced vaccum hoses that looked dry rotted.Replaced distributer,pick up looked rusted,didn,t help.cleaned IAC,it was really dirty,no change.replaced MAP,no change.Timing is moveing from 0 to of timing mark at times.Had Cats checked ,the shop said they are open.9/28 sent this question.rasmataz recommened clean IAC.It was dirty for sure.computer maybe?
Oct 9, 2010 at 1:07 PM
  • 75,988 POSTS
Probable causes of an engine running rich are as follows:
1.Excessive fuel pressure can be cause by restricted fuel return line or defective fuel pressure regulator.
2.Defective Oxygen Sensors.
3.Leaking injectors and fuel pressure regulator.
4.Coolant temperature sensor out of calibration.
5.Restricted air intake system.
Oct 9, 2010 at 8:34 PM
