1991 Chevy Camaro
300,000 MILES • V8 • 2WD • AUTOMATIC
JOHNSON21
MY CAR RUNS FINE ON THE HIGHWAY BUT WHEN IN TOWN IS CUTS OUT AND SOME TIME KILLS.
Jun 29, 2010 at 8:52 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 29, 2010 at 9:13 AM
