1991 Chevy Camaro
RED ROBIN
Engine Mechanical problem
1991 Chevy Camaro V8 Two Wheel Drive Automatic
i bought a1991 camero 5.7 v8 the person i bought it from said it blew a head gasket so they took it a part and had the heads resurfaced and the valves down and pressure tested put it back together and it had 2 dead cyl so i bought the car thinking the valves were to tight but i was wrong so i took that head off my self and had it tested and it was fine so then i was told the rings were causing the problem so i put in new piston rings and thguy already put in new lifters so then none of this help so i put in new lifters and plugs and cap rotor and check the plug wires still have the same problem but now i have three cylinders missing can you help? thanks bill
Mar 21, 2010 at 3:37 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following-inspect and test all the following below:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Mar 21, 2010 at 10:45 AM
RED ROBIN
is there any posibility it could be the computer?
Mar 21, 2010 at 2:51 PM
  • 75,988 POSTS
Check the engine compression both dry and wet tests
Mar 21, 2010 at 3:08 PM
RED ROBIN
i just put new rings. valve job, lifters ,spark plugs rotor cap and check plug wires it has a blue spark and new injectors number 4 6 8 on passenger side are the dead cylinders could it be computer? or dist.
Mar 22, 2010 at 12:41 AM
  • 75,988 POSTS
Is this a TBI or MFPI fuel system
Mar 22, 2010 at 7:21 AM
RED ROBIN
there is 12 volts to those 3 injectors could the new injectors be bad?
Mar 22, 2010 at 1:02 PM
  • 75,988 POSTS
Use a noid lite on the injector harness if it doesn't flash there's a problem with the computer ground drivers for those cylinders.
Mar 22, 2010 at 1:13 PM
