1991 Chevy Camaro
1991 CHEVROLET CAMARO
98,000 MILES • 6 CYL • 2WD • MANUAL
ANTHONIE GOODRICH
can fusible links make a car not start, and which ones make a car not start.
Mar 26, 2009 at 10:34 AM
BILLYMAC
  • 2,204 POSTS
no they can make a car not crank over not charge but will not cause a crank no start condition. what will.. timeing distributor ignition module coil fuel pump ecm. blown fuses.. good luck billymac
Mar 26, 2009 at 10:39 AM
When the fusible links blows no power will go in the vehicle. This fuse is just like a main breaker in your house nothing will come on if its defective
Mar 26, 2009 at 10:45 AM
