1991 Camaro rs 3.1L 218000 miles
BRYANANJA
91 Camaro, 218000 miles, 3.1 L
When I start the car it revs up to about 2500 rpm, and than takes a while to settle down. While driving at low speed the rpm`s surge high and low until it dies. We brought it to Pep Boys they did a engine diagnostic test and it was ok. They cleaned the fuel injectors and checked the vacuum hoses. The car has still the same problem
May 31, 2007 at 4:44 PM
E40WATER12
  • 522 POSTS
I would take a look at youre IAC sensor could be carboned up, Also TPS sensor could be sticking, Also youre map sensor mayneed to be checked.
Jun 7, 2007 at 9:03 PM
