1990 Chevy Camaro running tempertures
158,000 MILES • V8 • 2WD • AUTOMATIC
PECHUERTA
I have a 1990 IROC Z28 350 and I want to know the normal running tempertures also if both fans should come on at the same time and at what temperture should they come on?????
Apr 30, 2009 at 3:01 PM
2CARPRO JACK
  • 11,533 POSTS
It should be a 195 t-stat so the car should run around that temp give or take a few degrees.The fans wont come on til about 230, I know it seems high, but that is how it is designed. If I remember correctly both fans will come on to cool the engine, but only one when the a/c is on for airflow across the condensor. Look for debris plugging up the radiator and bags in the nose of the car, they are like vacuum cleaners for the road.
May 1, 2009 at 1:13 AM
