1990 Chevy Camaro RPM Drop
1990 CAMARO
Engine Performance problem
1990 Chevy Camaro V8 Two Wheel Drive Manual
when the A/C Clutch kicks on, .. you experience a 200 rpm dip when the clutch comes on...even when heater is on. Causes enigine to idle too low. Can you disconnect the a/c clutch wire conection for the winter so that the clutch wont engage when the heater is on? Transmission is auto not manual.
Oct 17, 2009 at 3:18 AM
  • 110,248 POSTS
You can disconnect it, but your defroster won't work as well. The AC is used to help dehumidify the air. Thus, it clears the windshield faster.
Nov 1, 2009 at 3:55 AM
