1990 Chevy Camaro Location of compressor relay
1990 CHEVROLET CAMARO
JHUERTA22
  • 15 POSTS
Air Conditioning problem
1990 Chevy Camaro V8 Two Wheel Drive Automatic 100xxx miles
I'm suppose to replace the relay for the A/C compressor, but I'm not sure where it's located on the car. Can you help me out here?
Sep 7, 2009 at 2:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle's A/C compressor control relay is located on the left side of the firewall, to the left of the brake booster.
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_169.jpg
Sep 7, 2009 at 2:38 PM
JHUERTA22
  • 15 POSTS
Ok, I found what you are talking about as to the three relays on the left side of the firewall, but I'm not sure which one it is. I included a picture of the setup in my car.
https://images.2carpros.com/forum/automotive_pictures/406383_IMG00294_2.jpg
Sep 7, 2009 at 2:55 PM
BLUELIGHTNIN6
  • 16,542 POSTS
should be the middle one. you can match up the OEM part number to the new relay if needed.
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_948.jpg
Sep 7, 2009 at 2:59 PM
JHUERTA22
  • 15 POSTS
Well I've just tried all but one relay and the clutch on the compressor still won't engage when the A/C is turned on. When I checked the wires that ran to the compressor I had no juice from them. I figured it was the relay, but it could be a pressure valve. Any help here?
Sep 7, 2009 at 3:27 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry, I'm not big on A/C systems. I will inform the other 2CarPro Techs to see what they can come up with for you though.
Sep 7, 2009 at 3:38 PM
JHUERTA22
  • 15 POSTS
Thanks for helping out. Saves me time and money, both of which I have little of to work on my car.
Sep 7, 2009 at 3:41 PM
