1990 Chevy Camaro Blower motor not running
1990 CHEVROLET CAMARO
JHUERTA22
  • 15 POSTS
Electrical problem
1990 Chevy Camaro V8 Two Wheel Drive Automatic 100xxx miles
My blower motor stopped running this morning. It was working fine last night and today I can't even get any power out of it. I checked and replaced the blower resistor on it and it still wouldn't kick on. What else do I need to check?
Sep 9, 2009 at 6:15 AM
JDL
  • 16,098 POSTS
You need to check circuits at blower relay. You can also take the connector loose from the blower motor, use jumper wires to battery + and negative, see if the motor will run, if not, faulty motor. You probable need an inline fuse on the jumper.
Sep 9, 2009 at 6:30 AM
