1989 Chevy Camaro with a 2.8 fuel Injected
JMART307686
We put the engine in, it has 70,000 miles. We can start it by going right off the battery, however we can not get the car to start by turning the key over. When we turn the key we get lights, blinkers, dash lights ect... However we can not get the engine to try to do anything by the key. What should I do?
Jun 16, 2007 at 5:53 AM
KIRBSTER269
  • 14 POSTS
There is a fuse and there is a relay find the 2 and check those first you have power with the key on thats normally the pink wire coming off the ignition the starter wire is normally yellow<< this isnt always true but common with gm vehicles try and follow that yellow wire test it first at key and see if power is there when in start position and go from there good luck
Jun 24, 2007 at 2:30 PM
