1989 Chevy Camaro Spark Plugs
VIGILJJ
Engine Mechanical problem
1989 Chevy Camaro 6 cyl Two Wheel Drive Manual
i recently brought this car thinking i could fix this problem, which is that the spark plugs are gettint wet with gas. but can not figure out what it could be? do u know what it is?
May 10, 2010 at 10:22 AM
  • 75,988 POSTS
Check the fuel pressure if its within specs if okay -check if you're getting injection pulses from the injector/s
May 10, 2010 at 8:38 PM
