1989 Chevy Camaro shift problems
126,000 MILES • V8 • 2WD • AUTOMATIC
89IROCZZ28
i need some help my transmission isnt shifting into overdrive there is no slipage when the transmission shifts gear it just wont shift into over drive i changed the fluid put lucus in it and changed the filter didnt help any i dont know if it is the shift sileniod or the tv cable is out of adjustment or the tranny just needs to be rebuilt and another question iam having a winning noise from the rear end of the car dont know if it needs wheel bearing or rear end fluid is low when i shift it in nutraul while driving it quitens down [img:37d750c630]http://www.2carpros.com/forum/automotive_pictures/422974_IMG00280_2.jpg[/img:37d750c630]
Oct 17, 2009 at 11:00 AM
MICKEY-D
  • 304 POSTS
I would try adjusting the cable first. Your rear end noise sounds like it would be pinion bearings.
mickey-d
Dec 4, 2009 at 4:24 PM
