1989 Chevy Camaro Fuel Injectors
1989 CHEVROLET CAMARO
HNDRXJIMMY
Electrical problem
1989 Chevy Camaro V8 Two Wheel Drive Automatic
I am not getting any power to the fuel injectors. I have rplaced the ECM and still no power. The car can sit for hours then start up. After running a while it will not start again. Thats when there is no power getting to the injectors.
Oct 14, 2008 at 5:12 AM
DOCFIXIT
  • 18,828 POSTS
Check to see if you loose ing fire to plugs. If so ignition module in dist bad.
Oct 15, 2008 at 1:33 AM
