1989 Chevy Camaro difficult to start once hot
HLHPA
Engine Mechanical problem
1989 Chevy Camaro V8 Two Wheel Drive Automatic
I rebuilt a 1989 Camaro ,350 , TPI. It will only start with remote switch, not from key. It starts great on second try, never on first. But I keep getting stranded, not ever time, but once hot, It cranks and has spark, but will not run. If I let it sit for a while, up to one Hr. It starts right up again.
Thanks for your help
Nov 19, 2009 at 6:27 AM
GOTAY5
FIRTS STEP CHECK THE RESISTANCE ON ALL FUEL INJECTORS WITH A MULTIMETER.
COLD ENGINE----- 16.0 ohm
HOT ENGINE----- 12.0 TO 15.O ohm IS RESISTANCE IS LOW 12.0ohm (HOT ENGINE) REPLACE FUEL INJECTORS.......PROBLEM FIX
Nov 30, 2009 at 2:51 AM
