1989 Chevy Camaro carbon build up
REDDCOWBOYS
Engine Mechanical problem
1989 Chevy Camaro V8 Two Wheel Drive Manual
why do I get carbon build up in my distribuator cap. Every 3 months or so I have to open the cap, sand down the connection points as they build up a carbon deposit and I can't start my car. I'm told it's running rich possibly.
Sep 12, 2010 at 7:26 PM
HMAC300
  • 48,601 POSTS
your carbon in the dist cap is coming from the button under the coil wire. It may be a cheap cap and rotor. Replace it with a name brand cap and rotor and make sure it's not made in China. the rotor where it hits' the distributor cap may be sharp and is grinding off the carbon. Also when your tighten the cap down tighetn the screws down even ly not one then the other.
Sep 14, 2010 at 10:43 AM
