1989 Chevy Camaro car pulls to the right while braking
1989 CHEVROLET CAMARO
91,000 MILES • V8 • 2WD • AUTOMATIC
IROCEY
Car pulls to the right while braking
Removed the lines between the master cylinder and the proportional valve at the valve had good flow.
The left front brake caliper is not releasing completly so I cracked the line and it released easly with help c-clamp. So the caliper is good. The right side appears to be working correctly. No abs or anything like that.
Just 4 wheel disc. The right front pads are worn more but were still in good shape.
My question is if this sounds like a bad proportional valve? Looks like there a right/left front circuit and then both of the rear run off one circuit?
Thanks
Ty
Aug 16, 2008 at 12:20 PM
DOCFIXIT
  • 18,828 POSTS
Flex brake hose has internal rupture checking pressure between hose and caliper. Replace hose.
Aug 19, 2008 at 1:12 AM
