1988 Chevy Camaro Possible blown gasket
212,000 MILES • 6 CYL • 2WD • MANUAL
PANFILO
Hi, guys thank you for taking the time to
answer my question. I have a possible blown head gasket and I don't if I should go for the entire engine overhoul or just fix the head gasket. My car is running well ,not major engine overheating running smooth
May 26, 2010 at 9:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if it's just head gasket then no reason at all to replace or rebuild the engine. if the head itself is cracked, then you may choose to replace engine with used one instead of just buying a reman head.
May 26, 2010 at 9:36 AM
