1988 Chevy Camaro no fuel coming out injectors
ROBALL57
Engine Mechanical problem
1988 Chevy Camaro V8 Two Wheel Drive Automatic
Car won't start...it will turn over for ever but won't start...I replaced the fuel pump relay , replaced the fuel filter, replaced the fuel pump, new spark plugs, changed the oil and still now fuel from injectors......if I spray fuel down into throttle body below injectors, the car wants to start....what else could it be...fuel pressure assembly( maybe the spring is not functioning)or could it be fuel pressure....how do I check if it is the fuel pressure and if it is how do I repair it , or what do I need to replace........thanks for all your help...I am trying to get my 1988 camaro T.B.I 305 V8 back on the road for my son who is soon to be getting his licence.(I am the original owner and I thought it would be great if my son could keep it and drive it one day) Thanks Again
Mar 22, 2009 at 12:21 PM
  • 75,988 POSTS
Check the fuel pressure and also for injection pulses
Mar 22, 2009 at 1:03 PM
