1988 Chevy Camaro clutch
150,000 MILES • 6 CYL • 2WD • MANUAL
AWSOMEDAVID9
  • 6 POSTS
well my car was running fine but when you press on the clutch there is no rpm drop and its having a hard time shifting into 2nd. also when i took it out last the when i was going about 10 mph there started to be a sort of grinding noise and the car when in gear would not move very fast...could this be the clutch or somthing along those lines
Aug 25, 2009 at 12:09 PM
PEAR69
  • 1,482 POSTS
Yes, it sounds like the clutch and the throwout bearing.
Aug 25, 2009 at 7:42 PM
