1988 Chevy Camaro
KIYONA
  • 1988 CHEVROLET CAMARO
Engine Performance problem
1988 Chevy Camaro
the car is not getting enough power to pick up speed
Wednesday, September 23rd, 2009 AT 12:47 PM
Do you have a check engine light and when was the last tune-up?
Could be one of the following below:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Wednesday, September 23rd, 2009 AT 1:07 PM
