1987 Chevy Camaro Rear Axel Seals
1987 CHEVROLET CAMARO
GBLANCHARD
Drive Train Axles Bearings problem
1987 Chevy Camaro V8 Two Wheel Drive Automatic
How do I go about pulling the axels out ,this car has the limited slip rear end so it's not as easy as most i have work on where you just push the axels in and remove the clips.I have no drawing on this rear end.any suppestions would be muchly appreciated.
thanks
glen b
May 1, 2009 at 5:23 AM
DOCFIXIT
  • 18,828 POSTS
Ctype diff. Remover cover collect oil, remove set screw slide shaft down, push in axle remove C clip.MAKR SURE not to turn axle or D shaft or stuff will fall out
May 3, 2009 at 6:29 AM
