Can a decrease in oil pressure to 0 during normal engine operation on a small block 350 be due to damaged valve seals or worn piston rings?
Nov 14, 2009 at 7:22 AM
MICKEY-D
✓Experienced Mechanic
No. Low oil level,old, or worn out oil(needs changing), or oil viscosity too thin. Worn valve seals, and/or worn rings will cause excessive smoke, but not loss of oil pressure.
mickey-d
