1987 Chevy Camaro have trouble starting
EASTCOASTBANGA
  • 1987 CHEVROLET CAMARO
  • 6 CYL
  • 87,000 MILES
Car sat for months. It started up fine every now n then. Recently started driving it but has alot of trouble starting. Has good fuel pump and new fuel filter. Once I get it started it runs perfect. But to get it started is a hassle. It wants to start but hardly ever turns over. What can I do? Thanks.
Wednesday, June 30th, 2010 AT 9:52 AM
INTERNETMECHANIC
  • 700 POSTS
When the problem occurs, your saying it cranks good but won't start? If it has been a while, I'd give it a tune-up. With extended crank, have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Even if the fuel pump is good, if there is something wrong with the wiring circuit, the pump won't run. If the pump gets voltage from the oil pressure switch, instead of the relay, that can cause an extended crank. Any applicable trouble codes.
Wednesday, June 30th, 2010 AT 11:34 AM
